Sponsored by: CARiD
95 Land Rover Discovery not geting fuel to injectors
Old Aug 22, 2011 | 07:07 PM
RichardLester's Avatar
Default 95 Land Rover Discovery not geting fuel to injectors
Hi all i have a 95 land rover discover with a 4.0 motor. I had it quit runing over the winter and am now am trying to repair it. I replaced the fuel pump and been trying to reduce the possibilities. The rover with start with carb cleaner and it geting fuel to the rail i also made sure it was geting spark so i am kind of at a loss. I think it might be thr crankshaft sensor or fuel regulator. Have any ideas would love your feed back thanks
Old Aug 22, 2011 | 08:53 PM
collin Barrows's Avatar
I had the same problem, turned out a $2 vacuum hose was the culprit...
Old Aug 22, 2011 | 09:00 PM
Check fuel rail pressure at schraer valve, should be 32-34 PSI, if good, that lets the regulator off the hook. Could also be sensors, they can usually be unplugged and tested with an ohm meter. FP regulator is a vacuum operated device.
IMHO using starter spray for these sorts of tests is not in your best interest - hard on the motor.
Old Aug 22, 2011 | 09:12 PM
I'm just guessing here, bad fuel pressure regulator.
Old Aug 24, 2011 | 08:37 PM
Rovin4life's Avatar
is the ecu rotted out?
Rovers4sale
Sep 6, 2012 09:37 AM
Rovers4sale
Jun 1, 2012 01:46 AM
howardw
Aug 15, 2009 09:35 AM
tbraith
Jan 15, 2008 01:24 PM
