95 land rover discovery heat/ac not blowing
Old Aug 5, 2013 | 11:21 AM
niyanakees's Avatar
Default 95 land rover discovery heat/ac not blowing
When I turn on the heat or ac I hear the change in the engine like its working but nothing blows out. What could this be?
Old Aug 5, 2013 | 11:35 AM
fuse, fan motor, relay,.... if the AC clutch is engaging (one line on compressor gets cold). The fuse link MF2 under hood (bolt in fuse) can take out the fan, but there is also a set of speed control resistors and the fan itself, which you get to by removing the cardboard under glove box, then 3 fan bolts.
Old Aug 5, 2013 | 11:46 AM
niyanakees's Avatar
thanks Ill check these options
Summer681
Dec 5, 2023 07:21 AM
dfiring
Aug 29, 2012 09:26 PM
bulldozer32
Nov 12, 2010 03:00 PM
JStephen
Feb 2, 2010 06:59 PM
pressure_welder
Nov 21, 2008 08:21 AM
