96 Disco Overheat Troubleshooting
Old Nov 14, 2012 | 04:11 PM
Here is what you don't want to see on WP - wobble, eats aluminum, calcium build up. Keep bolts in order, the lengths vary.
Attached Thumbnails 96 Disco Overheat Troubleshooting-p1030596.jpg   96 Disco Overheat Troubleshooting-p1030593.jpg
Old Nov 23, 2012 | 01:04 PM
joe_camel's Avatar
4wd High
Thanks Savannah, the WP looked great, the impeller had a few specks of copper on it as if the PO had poured some kind of stop leak in the system.
Anyway I got the new radiator in and the problem is without a doubt solved. The ODB scanner will show up to ~200 F for a very short period as it warms up, but once the tstat opens up it'll never get above 180 or so. This is just idling, with heater or A/C both on and off, haven't taken it out for a drive yet. I think I can say I learned a valuable correlation through this troubleshooting.
If the engine overheats even at idle and you have these conditions:
1. heater off while idling = overheat
2. heater on while idling = overheat
3. heater on while revving = cools back down + *extremely* hot air through the cabin vents
Then:
The radiator is not sufficient to cool the system and pushing more water through the heater core by running the water pump at higher RPM was acting as a sort of back-up radiator.
Thanks again for everyone's helpful posts!
Old Sep 5, 2013 | 02:14 PM
sumeet's Avatar
I know this is an older post, but thanks anyway for everyone's detailed responses. I'm learning alot about my overheating issues.
Halftrack99
Jul 25, 2015 10:52 AM
fuze-17
Sep 9, 2011 02:24 PM
AZRover
Jun 5, 2011 09:47 PM
ajs1iron
Mar 8, 2007 12:22 AM
whitedisco11
Apr 27, 2006 07:42 PM
