98 Disco front brakes locking on!
Old 08-08-2016, 11:11 AM
billrafoss's Avatar
3rd Gear
Default 98 Disco front brakes locking on!
Lately my front brakes have been locking on.
Started with a new ABS sensor. Seems to be a build up of pressure in the master cylinder. When I crack the nut on the cylinder, it releases the brake fluid and the brakes unlock.
Installed a new brake pressure release valve, but locking on continues.
Any ideas? Would the master cylinder itself cause this? I ruled it out b/c the brakes are working.
Problem seems greater in hot weather.
Any suggestions?
Old 08-08-2016, 12:14 PM
fishEH's Avatar
Did you recently replace you MC?
Old 08-08-2016, 08:59 PM
stillruns's Avatar
Where is the MC located and why does it need replacing?
Old 08-12-2016, 04:36 AM
loanrangie's Avatar
Is your vac booster leaking vacuum into the m/c ?
troy24
05-18-2013 09:14 PM
Billmrshll
07-19-2011 05:13 PM
FightOnUSC79
11-26-2010 09:43 AM
johanba
04-03-2007 11:37 AM
Quick Reply: 98 Disco front brakes locking on!
