98 Disco front brakes locking on!
Old Aug 8, 2016 | 11:11 AM
billrafoss's Avatar
3rd Gear
Default 98 Disco front brakes locking on!
Lately my front brakes have been locking on.
Started with a new ABS sensor. Seems to be a build up of pressure in the master cylinder. When I crack the nut on the cylinder, it releases the brake fluid and the brakes unlock.
Installed a new brake pressure release valve, but locking on continues.
Any ideas? Would the master cylinder itself cause this? I ruled it out b/c the brakes are working.
Problem seems greater in hot weather.
Any suggestions?
Old Aug 8, 2016 | 12:14 PM
fishEH's Avatar
Did you recently replace you MC?
Old Aug 8, 2016 | 08:59 PM
stillruns's Avatar
Where is the MC located and why does it need replacing?
Old Aug 12, 2016 | 04:36 AM
loanrangie's Avatar
Is your vac booster leaking vacuum into the m/c ?
troy24
May 18, 2013 09:14 PM
Billmrshll
Jul 19, 2011 05:13 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
johanba
Apr 3, 2007 11:37 AM
