98 le fuel gauge not working
Old Dec 14, 2023 | 06:59 AM
Trashpanda's Avatar
Default 98 le fuel gauge not working
I replaced the fuel pump assembly and wiring harness because it needed it and the gauge still doesn't work. Even the ultragauge says 15 gallons no matter how much I drive or fill it. Anything I should look at since it doesn't seem the ecu is getting the correct reading?
Old Dec 15, 2023 | 07:53 AM
WaltNYC's Avatar
Here is the diagram. see page 116 of the pdf in the google drive linked below etlj970x.pdf (Section E1, pages 4-6)
Get the multimeter out and test each individual hop, point to point. then test the entire run.
Old Dec 15, 2023 | 08:48 AM
Trashpanda's Avatar
thanks, that'll be super helpful. I cant open the link right now, does that have wire colors?
Old Dec 16, 2023 | 06:07 AM
WaltNYC's Avatar
yes. colors are the letters next to the lines.
“GB” in this case. Green/Black
Old Dec 16, 2023 | 10:23 AM
Trashpanda's Avatar
thanks
Old Dec 16, 2023 | 10:36 AM
Trashpanda's Avatar
the speedo is also off at increasing increments as speed increases, if theyre connected at all.
redrover75
Jul 15, 2023 08:22 AM
fieldeffectt
Mar 15, 2022 09:23 PM
redrover75
Jun 23, 2020 11:48 AM
markdeg
Jan 7, 2019 09:43 AM
Thornchabot
Oct 2, 2018 02:11 PM
