98 Rebuild
Old Feb 7, 2015 | 05:03 PM
terryabel2's Avatar
Default 98 Rebuild
When I first drove this D1 I fell in love now its braking me. First thing to happen was to replace the exhaust with cats new o2 sensers all 4. Ran better but not perfect. Repaced kick down cable,ideal air senser,tps always running better. Then one day I'm driving on the interstate and it starts to back fire and run bad running very rich new cats turning red. Replaced maf nothing changed. Any ideas new coil packs wires and spark plugs. Doesn't matter if I'm driving it or not fuel pressure good no codes.
Old Feb 8, 2015 | 04:12 PM
archaeology_student's Avatar
Have you cleaned the IACV (internal air control valve)?
Old Feb 9, 2015 | 08:42 AM
terryabel2's Avatar
Default pulling hair out
Yes it has Ben replaced and socket cleaned
Old Feb 12, 2015 | 01:43 AM
CUpgt's Avatar
Champion plugs and Kingsborne 8mm wires are never a bad idea. I don't know what emissions laws are where your at but I parted ways with my cats a while ago and did not have any adverse effects.
Old Feb 12, 2015 | 07:15 AM
TOM R's Avatar
Codes?
Old May 23, 2015 | 02:40 PM
terryabel2's Avatar
Default figured it out!
Thank you!! Firstly the two wires for crank sensor were melted together. Misfire was caused by tine in crank position ring bent over. Slowly tapped it back in place and when sensor finally saw it it started running smooth and no problems at all!
Old Jun 15, 2015 | 08:19 PM
terryabel2's Avatar
Default it continued
Started miss firing at 2000 rpms had to change crank position sensor bought a second one for parts if any one needs anything
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
sanchez
Aug 3, 2006 11:28 PM
