ABS = annoying..yeah
Old Dec 12, 2010 | 11:39 PM
  #31
thehun's Avatar
by yanking the modulator..meaning you took the 30a fuse right...now question...when i looked at the fuse there is two fuses for the ABS one is a 30a and the other is a 40a..what gives
Old Dec 12, 2010 | 11:45 PM
  #32
Lee97Disco1's Avatar
Default No, actually.....I meant "Yanked".
No, I mean that I removed the ABS Modulator together. It was stopped-up would not allow fluid to the front brakes. I just used the existing brake pressure regulator and re-piped the lines. They work GREAT!
Old Dec 12, 2010 | 11:49 PM
  #33
thehun's Avatar
did you get a new proportioning valve?
Old Dec 13, 2010 | 12:18 AM
  #34
Default Nope
Nope. The only new items was brake lines. Amazing brakes.
Old Dec 13, 2010 | 06:09 AM
  #35
antichrist's Avatar
It's the same proportioning valve. Land Rover specs a different MC between ABS and non-ABS, but I've not been able to determine any difference, and a number of people have been running the ABS MC after removing the pump so it appears to not be an issue.
This is how it needs to be re-plumbed.
ABS
Non-ABS
The illustration makes it look like it's a different valve, but it's not. In the ABS plumbing one port on the valve is plugged.
Old Dec 13, 2010 | 07:00 AM
  #36
ngarover's Avatar
ABS
Non-ABS
Great information! I'm defiantly going to re-plumb the 96 now.
Old Dec 13, 2010 | 09:11 AM
  #37
Default Here's my work.....
Here are some pics of the end result.....
Old Dec 13, 2010 | 01:31 PM
  #38
antichrist's Avatar
Why didn't you leave the proportioning valve in it's stock location? It would be a tidier install.
Old Dec 13, 2010 | 01:50 PM
  #39
thehun's Avatar
pulled the 30a abs fuse..no CEL light like i heard it suppose to..kind of weird...made my pedal feel a bit better
Old Dec 13, 2010 | 04:05 PM
  #40
calebbo's Avatar
So does anybody know what to do?
