Adjustable panhard rod question
Old Mar 22, 2022 | 12:16 PM
dcphotos's Avatar
Default Adjustable panhard rod question
So they say there are no stupid questions so here we go:
I have a new to me '97 Disco.
It has a 2" lift so I've been told.
The steering wheel is off to the left from center about a 1/2" or so going down the road and there is a bit of play in the wheel. Again, about a 1/2" of play.
I was told I needed a panhard rod as the bushings are shot and to get a heavy duty adjustable one. It's on it's way as is an OME dampener.
My question is how do I know how much to adjust the panhard rod?
Thanks,
dcphotos
Old Mar 22, 2022 | 03:55 PM
dcphotos's Avatar
I promise I searched around before I posted this but now that I have I see the "Related Topics" below my post and it looks like I've found my answer there.
Old Mar 22, 2022 | 08:07 PM
aemnky606's Avatar
I put a straight edge on my tire and measured from the frame out to the straight edge on both sides. Found the difference and adjusted accordingly. When you lift the truck it always moves to the drivers side.
The pan hard bar will do nothing for you wheel being off. That will get fixed with an alignment.
Old Mar 22, 2022 | 09:33 PM
JohnZo's Avatar
To adjust the steering wheel to center, the track rod (front steering linkage) can be adjusted. To adjust toe-in, the drag link (rear steering linkage) is adjusted. There are other adjustments that can impact steering wheel position, but yours is not off by much.
To adjust play, the steering box can be adjusted, but yours doesn't sound too bad.
Old Apr 12, 2022 | 05:49 PM
dcphotos's Avatar
Default Found the problem to the loose steering
Turns out, the issue with the play in the steering wheel was cause by the lower steering link that connects the steering shaft to the steering box. It had a alloy one and when I bought the Disco the guy gave me what looked to be an old OEM one.
I wondered why till I grabbed the steering shaft and saw it move back and forth before engaging the splined shaft out of the steering box. Turns out the splined female end was wallowed.
This was the problem all along.
Also, I realized that whoever installed the h/d alloy one didn’t bother to center the steering wheel. I fixed two problems by installing the factory coupler.
Old Apr 12, 2022 | 08:05 PM
robertf's Avatar
that is the factory coupler
Old Apr 12, 2022 | 08:22 PM
dcphotos's Avatar
So this one is aftermarket?
im new the Discovery’s. Been a Triumph Spitfire guy my entire life.
Old Apr 13, 2022 | 07:36 AM
JohnZo's Avatar
Nice to hear a happy ending. Good lesson in persistent troubleshooting, paying attention to basics, and using all your "clues". Seems that's how it is with Discos.
Old Apr 13, 2022 | 06:19 PM
robertf's Avatar
the steel coupler is off a non airbag range rover classic
DiscoCam
Jun 24, 2016 12:03 PM
texasdisco1
Apr 9, 2013 06:16 AM
coors
Jan 30, 2013 02:25 PM
kenk
Jun 6, 2011 05:45 PM
Garrett
Dec 24, 2010 09:14 PM
