Airbag dash light on
Old Dec 8, 2019 | 05:10 PM
pavel's Avatar
4wd High
Default Airbag dash light on
Our '96 Disco 1 has had the airbag/SRS light on ever since I got an alignment. I removed the "clock spring" that tested badly for one of the circuits. Obtained a used replacement that tested fine. Installed it and the SRS light is still on. When I installed the replacement part, I saw an electric plug that doesn't seem to go anywhere. I don't remember unplugging this connection and so wonder if it is for something not on our vehicle.
There are two plugs that are connected (one is wrapped in grey foam for some reason) and a 3 amp fuse, but the 3rd plug has me baffled.
Any advice would be appreciated.
Old Dec 8, 2019 | 06:41 PM
Friday Night Disco's Avatar
What code are you getting? Could be a few different issues
Old Dec 8, 2019 | 06:52 PM
pavel's Avatar
4wd High
Unfortunately, my OBD reader doesn't read airbag or ABS codes, so I'm a bit in the dark. Could you give me an idea of some of the issues other than the "clockspring"? Thanks.
Old Dec 8, 2019 | 07:01 PM
turn steering wheel all the way to the drivers side, leave in that position and turn off the truck
disconnect the battery for 15 minutes
connect battery and check for srs light
Old Dec 9, 2019 | 09:04 PM
pavel's Avatar
4wd High
Thanks for the suggestion Friday Night Disco, but the SRS light is still on after following your instructions (I left the battery disconnected for an hour). Permit me to pick your brain even more...are there any other suggestions you could supply?
Here's a picture of the "extra" plug that I couldn't find a mate for. Of course, this is a Disco ! (1996) - obviously much earlier than your model.
Old Dec 10, 2019 | 11:18 AM
pavel's Avatar
4wd High
Followed your instructions Friday Night Disco, without success. Could I pick your brain for other suggestions?
Here's the mystery plug I mentioned (hope the picture comes through)
Cheers, Pavel
Old Dec 10, 2019 | 06:37 PM
pavel's Avatar
4wd High
Followed your instructions Friday Night Disco, but no success... the SRS light is still on. Does any other "attack" come to mind? Thanks!
Old Dec 10, 2019 | 07:04 PM
I wanted to rule out the steering wheel
let’s move to the seat belt tensioner
disconnect the drivers side and read the codes
that plug is not relevant to SRS. All SRS items will be yellow plugs
Friday Night Disco
Oct 4, 2021 05:55 AM
pavel
Dec 8, 2019 05:13 PM
bballjames
Dec 11, 2012 11:48 AM
losinov
May 29, 2011 10:59 AM
KeizerRover
Apr 8, 2009 10:36 AM
