Almost broken bent door and ignition key
Old May 1, 2018 | 04:43 AM
Jacquiec's Avatar
Default Almost broken bent door and ignition key
My key has bent and almost broken in half doors would not open. My only alarm is locked in 96 discovery 1 v8 4.0 series E Gems. Any ideas please my son had new key & ignition switch put in due to him breaking key in truck The new key was cut off a bit and very thin. It's stuck on my friends property. Can lock company copy key ace hardware can't or Fred Meyers.
Old May 1, 2018 | 07:49 AM
mirrajumper's Avatar
Default Ignition
BPUtah has a britpart ignition cylinder with wiring and keys for $60 bucks shipped. They also have a Lucas band for $130 shipped.
Old May 1, 2018 | 09:42 AM
jimvw57's Avatar
Ace hardware was unable to make a duplicate key that would work in my truck. I ended up contacting a locksmith with a mobile service who ordered the key blanks and I went to his office and he made 3 keys for me that worked with no problems.
Old May 1, 2018 | 11:00 AM
OverRover's Avatar
Can lock company copy key ace hardware can't or Fred Meyers?
Yes, ANY locksmith or even a hardware store with a decent key cutting machine can make a key for a '96 DI.
And it doesn't matter if it's an OE key blank (CWE10032L) or something like an Ilco (with or without the plastic cover), there is just nothing special about cutting it. No chip to deal with.
Old May 1, 2018 | 11:36 AM
Local dealer charges $85 dollars for the RAV4 aftermarket black key- not cut! Ace stocks them
for 7 bucks cut. Go figure!
Old May 1, 2018 | 11:52 AM
DavC's Avatar
had same issue. Went to a locksmith and had new keys made.
blanks were equivalent to Ilco x239 RV4 if that means anything to you, the new set differed from the old but unlock and start the car.
Keep the damaged key for use making duplicates but do not keep using it if possible.
Jvirgo416
Dec 28, 2014 02:19 AM
ls1morethanyou
Mar 11, 2014 07:57 PM
shreksbrother
Dec 12, 2011 10:25 AM
targotsi
Jan 22, 2010 02:32 PM
stevelg
Sep 7, 2006 02:20 AM
