only key is broken in half inside ignition
Old Mar 11, 2014 | 01:23 PM
ls1morethanyou's Avatar
Default only key is broken in half inside ignition
I have been searching for a way to get a key cut but everyone i have called wants 300+ dealer is at 395.
I have found some old threads where they say there was a diagram to get a push to start button and that would fix getting the truck started but i would still need a regular key cut to enter the vehicle. The last link i found said it was on discoweb but there is nothing there that sounds like it.
Anyone know of a place in the dfw that would cut a regular key or the diagram for the push button start.
All help is appreciated.
Old Mar 11, 2014 | 01:39 PM
Dan7's Avatar
$2 will get you a key cut at ACE or Lowes that will work to get into/start the vehicle. It just won't activate the alarm/imobilization/keyless features.
Old Mar 11, 2014 | 01:44 PM
cosmiccharlie's Avatar
Did you get the piece of the key out? You can remove the back/electric portion of the ignition switch and start it with a flat blade screwdriver. See third picture in the writeup below.
https://landroverforums.com/forum/di...ock-fix-35422/
Old Mar 11, 2014 | 02:48 PM
grandkodiak's Avatar
paperclip n superglue lol
Old Mar 11, 2014 | 03:26 PM
primussucks's Avatar
there is a key shop in Addison... that is where I got mine cut... Its over by the airport... but anyone should be able to cut the key (maybe not lowes or HD).
The disco doesn't have chip protection, so a blank key works fine, so long that you are not super locked... but I guess you have the remote, so that shouldn't be an issue..
if you get REALLY stuck, let me know, my buddy is a locksmith, and member of TX Rovers too
Old Mar 11, 2014 | 07:57 PM
truck is not super locked, and the remote is bad- contact points for the buttons broke(how i bought it). how do they cut they key without a key to copy from?
also i was a registered member on texas rover with the same screen name but i cant re-sign up nor can i retrieve my old usernames password.
The truck is out in plano by jupiter and 15th, if i cant find someone to come take a look at it ill deff appreciate the help!
Aus-trek
Dec 31, 2012 07:56 PM
iplayblues4u
Jun 30, 2010 06:02 PM
targotsi
Jan 22, 2010 02:32 PM
stevelg
Sep 7, 2006 02:20 AM
