Alternator rebuild??
Old Dec 1, 2013 | 07:51 AM
jimvw57's Avatar
Default Alternator rebuild??
I replaced my Alternator to fix my flickering lights problem. I decided to pull apart the old alternator that still works, just makes the lights flicker, and see what I can find wrong.
1) brushes have worn down the slip rings quite a bit,
2) capacitor on the output terminal is cracked in a bunch of spots,
3) regulator has a black line across it that looks like a burn mark.
diodes seem to check out OK. same with the field and stator.
Think I will try a regulator/brush assembly and see if it works for a spare.
Anybody have any suggestions??
Old Dec 1, 2013 | 08:17 AM
A spare is always a good idea. Alternators seem to grabbed first by partz vulturez that fly low and fast across the boneyard (get there first or go home empty handed).
My indy alternator shop takes a piece of crocus cloth, and holds it to the exposed copper parts while spinning, using a popsicle stick. Just a touch to clean them up.
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
barrylee66
May 22, 2009 09:43 PM
