Am I going crazy or is there some trick to this brake pin?? Urgent.
Old Sep 12, 2010 | 06:44 PM
  #31
As for the power steering leak, buy a quart of ATF with stop leak in it, add with that until the leak stops.
Took about half a quart to stop my leak.
Old Sep 13, 2010 | 09:44 AM
  #32
okdiscoguy's Avatar
Originally Posted by discomedic4
I would try White Shepard on the PS leak. It did wonders for mine and mine was like a 4" puddle every morning. It is way cheaper than a new gearbox or pump and like I said it worked wonders.
X2 on that one. Check all of your hoses. If you have the factory clamps on the return lines, cut them off and use worm style hose clamps. Also make sure your pitman arm is not loose. If everything is good and still leaking from the box, add 1/3 bottle of white shepherd to it.
Shark59
May 4, 2013 09:33 PM
Fitzpatrick
Feb 17, 2011 09:09 PM
Torancis_LR
Jul 10, 2009 11:27 PM
jasongilliland
Oct 2, 2005 04:04 AM
