Bought a Disco 1 via auction - need some advice please
Old Dec 7, 2024 | 10:38 PM
DiscosandDefenders's Avatar
8th Gear
Thanks Jim, hoping the same.
Old Dec 21, 2024 | 09:34 PM
8th Gear
So the Disco was collected and she's a beaut. There are some rust spots that need to be worked on but nothing too serious. We'll be posting some more pics when we get home and as soon as we manage to get her moving again.....
We drove from Vancouver to Idaho without a hitch - there were some moments that she was searching/hunting at idle but arrived safely at a friends house last night. This morning we tried to crank her but she's not turning over. We tested the battery, checked the earths, changed the ignition module, checked the TPS but she's still not firing up. There is fuel coming through and spark but she's just not getting going. Any ideas?? I have a new MAF and Fuel Injection Idle Air Control valve arriving on Monday.
Old Dec 21, 2024 | 10:32 PM
JohnZo's Avatar
If you get spark, but crank-no-start condition, then my first thought is low fuel pressure. Maybe clogged fuel filter after the long drive? See if it tries to start with a spray of starting fluid. If it runs with the MAF unplugged, could be the MAF is bad.
Check the OBD code display under the passenger seat (Looks like a black box, two digit codes, bright red), but Check Engine Light should be on if a code is set. Online JE Robison has a list of code meanings and troubleshooting information. You are going to love this truck, super simple once you get to know it. Disconnecting the battery will set code 02.
Last edited by JohnZo; Dec 22, 2024 at 10:30 AM. Reason: OBD code display built-in
Old Dec 22, 2024 | 08:58 AM
jimvw57's Avatar
mine was strange when I got it, try disconnecting the battery, then reconnecting it. See if it starts then. I ended up replacing the alarm computer to make it work.
olexandr
May 31, 2023 04:26 AM
Mark1107
Mar 17, 2023 02:45 PM
PilotHobs
Mar 13, 2023 09:35 AM
The Deputy
16
Nov 4, 2022 07:11 PM
N E WHR
May 2, 2021 09:41 PM
