Brake booster and brake light switch ????
Old Jul 13, 2014 | 06:20 PM
ihscouts's Avatar
Alright, measure the old booster rod and I hate to say but you'll be measuring the new one as well. Pick a spot on the boosters that is the same on both to measure from. I'll bet if you omit the spacer from the new one they both measure the same length.....
Old Jul 13, 2014 | 06:34 PM
fishEH's Avatar
Two plungers in the upper right of the pic. One is the cruise cancel, the upper one is the brake light switch.
Here is how it looks with the brake pedal pressed down.
Like most things Rover you may need to get creative and use some sort of shim/spacer for the plunger to make contact, I've seen it done before.
Old Jul 13, 2014 | 06:50 PM
Rover Newbie's Avatar
Not sure it might be a optical illusion but your switch looks like the plunger extends further than mine does. ( I removed the other switch to get a clearer pic) That is the plunger at full extension.
Attached Thumbnails Brake booster and brake light switch ????-img_0637.jpg   Brake booster and brake light switch ????-img_0628.jpg
Old Jul 13, 2014 | 08:30 PM
fishEH's Avatar
Yeah that doesn't look like it's adjusted properly. Gently pull that red collar until it "pops", adjust the plunger out, pop the red collar back into the locked position again.
Old Jul 13, 2014 | 09:09 PM
Ok, pulled it out till it "popped" and tried to adjust the plunger 3 times with no success. Was pissed and thought I would try it one more time. Pulled the red collar and it "really popped" so much so that I thought I had broken the switch but the plunger moved. Brake lights now go off !!!! Success !!!!!
Thank you everyone for you input and assistance !!!
Funny how sometimes something so simple can throw things off.
Old Jul 13, 2014 | 10:46 PM
fishEH's Avatar
Glad you got it!
dillhole
Oct 30, 2016 04:43 PM
shezm
Dec 28, 2015 11:25 PM
kog50
Jul 9, 2012 08:41 AM
ajh
Oct 26, 2007 02:58 PM
1eyescooter
Jan 15, 2007 08:36 PM
