brake light comes on occasionally
Old Oct 22, 2012 | 01:10 PM
binvanna's Avatar
Default brake light comes on occasionally
any idea why the brake light sometimes comes on at odd times when the parking brake lever is down and hasn't been bumped? It comes on and then fades out at odd times.
I'm mostly wondering, what else is it connected to besides the parking brake lever switch? Is there a fluid level switch? That might explain it because the fluid gets sloshed around. I also noticed the light comes on when on steep terrain. But the fluid level is fine when the Rover is level and still.
Old Oct 22, 2012 | 02:03 PM
From RAVE:
Brake Warning Light
The brake warning light receives battery voltage with
the Ignition Switch (X134) in position II. It is
grounded by the Brake Fluid Level Switch (X111)
when the brake fluid level is low. It may also be
grounded when the Handbrake Switch (X191) is
closed. The brake warning light is also grounded by
a 3 second timer as a bulb check.
So if you unplug the sensor from the brake fluid reserve container, this should go away if it is that sensor. Of course, repair when possible, we don't want you to break something because your brakes are broke, which could make you broke as well.
Old Oct 22, 2012 | 03:26 PM
And if your fluid is low, that means your pads are getting thin and may need to be changed soon. When was the last time you flushed the brake system?
Old Oct 22, 2012 | 07:12 PM
honda50r's Avatar
Yup, the fluid in your reservoir is low.
Old Oct 23, 2012 | 07:07 PM
binvanna's Avatar
The fluid is above the min line and below the max. Pads and fluid have about 3000 miles on them both. I don't think it's a dodgy switch but maybe just getting knocked and sloshed around. Just another one of those warning signs you learn to ignore on a Land Rover I guess.
dillhole
Feb 20, 2020 02:30 PM
s10lowrider1994
Jan 19, 2013 09:54 PM
marlymarl
Apr 21, 2012 12:49 PM
vishrb
Nov 19, 2010 12:09 PM
bulldozer32
May 24, 2010 10:30 AM
