Brake lights and brake system
Old Feb 15, 2011 | 12:11 PM
ctystrickland's Avatar
6th Gear
Ok, that is something that I will look into for the light.
Old Feb 15, 2011 | 05:51 PM
Originally Posted by ctystrickland
Exactly, when it is grinding, like it has no pads (thats the sensation it feels like), it doesn't want to stop, like you are sliding on ice, when the tires stop, but the Rover keeps going.
You have 2 options.
First is read the tech section, there is a "how to" read your ABS trouble codes.
Second open your hood, find the fuse box on the passenger fender and remove the ABS pump fuse.
Then you can drive safely, you will NOT have any ABS but you will beable to stop.
Then you can go about fixing your ABS system if you so choose.
Old Feb 15, 2011 | 07:37 PM
6th Gear
Even though the ABS light isn't on?
Old Feb 15, 2011 | 07:39 PM
I assumed the ABS (Anti Lock) light was on.
Does the ABS light come on when you start the truck and then shut off when you reach 5mph?
Old Feb 15, 2011 | 07:48 PM
6th Gear
No, I'm sorry, I should have clarified that. It doesn't come on at all.
Old Feb 15, 2011 | 07:54 PM
Then either the bulb is burnt out or it has been removed.
That is easy to fix.
Lower your steering wheel as far as it will go.
Remove the 2 screws on the bottom of the instrument cowl.
Then lift/wiggle the cowl off and replace the bulb.
Then the light will be on all the time because there is a problem.
Right now you need to ask yourself how bad you want ABS.
You can read the codes with no bulb, the computer does not know the bulb is missing/burnt out.
So the ABS codes will be there.
If you do not care about ABS then just open the hood and remove the ABS pump fuse.
If you do care then read the codes, then pull the ABS pump fuse and when you are ready to fix the ABS put the fuse back and fix the ABS.
I would not replace the bulb unless you are going to fix the ABS.
My ABS pump fuse has been pulled for over 3 years now.
mark.broome
Jan 27, 2013 04:52 AM
RROJ
Jul 24, 2011 07:59 AM
blast20
Sep 3, 2010 12:18 AM
USMC_Denver
May 8, 2009 12:41 PM
klh113
Dec 17, 2007 02:13 PM
