brake pipes on NAS Discovery 1
Old Apr 6, 2019 | 08:41 PM
nathanb's Avatar
Default brake pipes on NAS Discovery 1
I need to make new brake pipes on the Disco 1. What are the fittings? 3/8, 10mm, -3AN?
I'm not just ordering replacement parts, but I need to make modified ones. Ideally, I'd use a banjo bolt for a tight right-angle into the D110 calipers I'm using. I either need an adapter from the extra length stainless braided flex lines I have already, or a short pipe. Yes, I can bend the existing pipes, but they're really too long. I'm hoping to find some universal parts that I can use, or make some pipes. I don't have a flaring tool and I don't even know what kind of ends to get.
Old Apr 6, 2019 | 08:54 PM
OverRover's Avatar
M10 X 1.0 with Bubble Flares
You can get pre-flared straight brake hardlines with line nuts attached in many lengths (plus adaptors if needed) at any Autozone, Advance, etc.
RockAuto also sells some premade hardlines.
Old Apr 6, 2019 | 09:01 PM
fishEH's Avatar
3/16" pipe
Old Apr 8, 2019 | 07:54 AM
whiskeynipple0088's Avatar
flaring is easy just takes a few practices.
make sure its a good flaring kit like rigid - dont go cheap it will twist and bend the pipe
I redid all the hard and soft lines on my 98 disco 4yrs ago.
I got all my parts from napa
sayeedA
Apr 19, 2017 04:41 PM
sDot
Sep 4, 2015 03:23 PM
calebbo
Jan 6, 2012 05:29 PM
bradical
Nov 2, 2011 09:36 PM
calebbo
Aug 22, 2011 07:37 PM
