Busted transmission cooler line R380 (pics)
![Question](https://landroverforums.com/forum/images/icons/icon5.gif)
so after going through a mud hole a small log managed to knock off my serpentine belt and rip my tranmission cooler line. lost all my fluid (ironically after changing my fluid). so my question is do i have to change the whole line? or can i just replace the rubber hose part? (i have not seen away to seperate the hose from the pipe) if not, would you happen to know where i can purchase a whole new pipe/line from? as i havent seen anything online. Instead of replacing with a genuine line/pipe would running a similar size hose from the cooler to the transmission replacing the pipe work? im assuming the pipe is to help cool the oil down however im running out of options. all help is appreciated, thanks!
the slash
![Name: rover123003.jpg
Size: 118.4 KB](https://landroverforums.com/forum/attachments/discovery-i-39/43965d1501380695-busted-transmission-cooler-line-r380-pics-rover123003.jpg)
![Name: rover123005.jpg
Size: 110.3 KB](https://landroverforums.com/forum/attachments/discovery-i-39/43966d1501380695-busted-transmission-cooler-line-r380-pics-rover123005.jpg)
connection to transmission i know its slightly dirty
![Name: rover123007.jpg
Size: 104.8 KB](https://landroverforums.com/forum/attachments/discovery-i-39/43967d1501380695-busted-transmission-cooler-line-r380-pics-rover123007.jpg)
the slash
![Name: rover123008.jpg
Size: 160.5 KB](https://landroverforums.com/forum/attachments/discovery-i-39/43968d1501380695-busted-transmission-cooler-line-r380-pics-rover123008.jpg)
Here' a link to a source, on the high priced side, but they have great exploded diagrams. Check Atlantic British and elsewhere, and consider one of the parts guys (dismantlers). If you have an automatic, the tranny cooler in front (towel bar) is also in series with one inside the radiator. You could splice the metal line with compression fittings. Heavy duty hose would also work for short time, you would want to flare pipe ends to keep it from slipping off. There is not a lot of pressure there, nothing like what is inside the tranny.
Land Rover Discovery I Transmission Cooling Parts Available from RoversNorth.com
bcolins
08-13-2013 06:41 PM
