Busted transmission cooler line R380 (pics)
Old Jan 7, 2012 | 07:32 PM
cationmoted's Avatar
Question Busted transmission cooler line R380 (pics)
so after going through a mud hole a small log managed to knock off my serpentine belt and rip my tranmission cooler line. lost all my fluid (ironically after changing my fluid). so my question is do i have to change the whole line? or can i just replace the rubber hose part? (i have not seen away to seperate the hose from the pipe) if not, would you happen to know where i can purchase a whole new pipe/line from? as i havent seen anything online. Instead of replacing with a genuine line/pipe would running a similar size hose from the cooler to the transmission replacing the pipe work? im assuming the pipe is to help cool the oil down however im running out of options. all help is appreciated, thanks!
the slash
connection to transmission i know its slightly dirty
Old Jan 7, 2012 | 07:55 PM
Here' a link to a source, on the high priced side, but they have great exploded diagrams. Check Atlantic British and elsewhere, and consider one of the parts guys (dismantlers). If you have an automatic, the tranny cooler in front (towel bar) is also in series with one inside the radiator. You could splice the metal line with compression fittings. Heavy duty hose would also work for short time, you would want to flare pipe ends to keep it from slipping off. There is not a lot of pressure there, nothing like what is inside the tranny.
Land Rover Discovery I Transmission Cooling Parts Available from RoversNorth.com
Old Jan 7, 2012 | 08:07 PM
You are going to need to replace it, you can Band-Aid it to get by until the new part comes in.
Check e-bay.
Old Jan 8, 2012 | 09:40 AM
thanks. also would anybody happen to know how to seperate the hose from the pipe?(second pic) if so, i could just replace the hose.
Old Jan 8, 2012 | 10:28 AM
You cant just replace the hose, you need to replace the whole thing.
If you take it off the truck you might beable to have a new one made.
Old Jan 8, 2012 | 11:03 AM
EricTyrrell's Avatar
Or if you got a lot of extra cash... Lucky8 Llc. - Take the road less traveled...
Old Jan 8, 2012 | 11:40 AM
hh65flyer's Avatar
No, it's a pressed-on compression fitting. You may be able to go to a tractor-repair type place and have them make some new ones for you. My local Napa makes hyd hoses on the spot.
Beaulim
May 2, 2014 08:03 PM
thehun
Mar 7, 2013 01:35 AM
Snafu / Disco Fries
Apr 1, 2012 07:37 PM
DarylJ
Apr 14, 2011 09:11 PM
