A/C on only leads to overheating
Old Jun 30, 2021 | 08:42 PM
Best4x4's Avatar
You can use a standard duty fan clutch vs HD/Severe Duty. Those usually don't roar, but they also don't cool as well as the HD/Severe Duty units. Efan issues = the shroud, the wiring, and finding an Efan which pulls 2800 CFM will be your battle.
Anyone can slap an Efan behind a radiator, but if you aren't using nearly all of the surface area to pull air thru the radiator = you are just making things worse. You will create hot spots and your temps will not be good. Also a lot of the Efans in the 2800 CFM and higher range sound awful all the time unlike a traditional Fan Clutch which only roars when it is engaged.
I did see a setup once which used 2 Efans on a decent bracket/plate/shroud, but the issue was then finding an Efan with enough CFM and I never did find any quality Efan's in the 2500 CFM or higher range.
Old Jul 1, 2021 | 08:29 PM
ononomos's Avatar
I use the Hayden 2991 fan clutch like Walt recommended and yes, it sounds like I’m about to take off down the runway. But these engines NEED as much cooling power as they can possibly receive.
Old Jul 4, 2021 | 08:16 AM
WaltNYC's Avatar
Has anyone tried the Hayden 2781?
Old Jul 5, 2021 | 05:41 PM
archaeology_student's Avatar
Well, it’s not the fans, as I have check All of them and they are all working at full.
I either still have an air blockage in the system or gunk creating a blockage.
I posted a new thread on it today as it does some weird things with the e-brake on and off on the cluster gauge.
Old Jul 6, 2021 | 08:27 AM
WaltNYC's Avatar
blockage can be a real issue.
Attached Thumbnails A/C on only leads to overheating-jpeg_2021-07-06_08-59-44_3.jpeg
WildPackofFamilyDogs
Apr 29, 2021 04:50 PM
Robert Booth
Mar 21, 2017 03:08 PM
oilspotLR
Aug 6, 2015 06:59 AM
wjchastain
Nov 28, 2012 08:43 PM
troopie
Jan 26, 2010 09:31 AM
