Can someone tell me what this part is?
Old Jun 28, 2014 | 09:26 AM
BrianTN's Avatar
Default Can someone tell me what this part is?
Well I screwed up. I was changing the transfer case oil in a 97 Disco and damaged this hose. Just turning the ratchet while rubbing against the hose took out a large chunk of it. I guess the rubber from 97 is pretty brittle. Does anyone know what this hose goes to? And a part number?
BrianTN's Avatar
Old Jun 28, 2014 | 09:45 AM
fishEH's Avatar
Isn't that the cable that actuates the parking brake drum?
Old Jun 28, 2014 | 10:15 AM
TOM R's Avatar
Parking brake cable it is ok
Old Jun 28, 2014 | 10:44 AM
BrianTN's Avatar
Is it just rubber that surrounds the cable? It's ok to leave as is? Btw, what tool do you guys use to remove the fill plug? I used my 1/2" ratchet, but that happened. I tried a 3/8" with 1/2" adapter, 1/2" w extension, 1/2" w swivel fitting, nothing seemed to fit well in that spot.
Just to show where the parts ends:
Old Jun 28, 2014 | 04:02 PM
TOM R's Avatar
parking brake it is ok
is there crap in the fill plug? think I use a skinney extension
Old Jun 28, 2014 | 04:15 PM
BrianTN's Avatar
The fill plug was empty, I had issues with clearance. The extensions made both ratchets too long to fit, and the 1/2" ratchet would barely fit along side the part that connects to the rear drive shaft. The tip would not fit entirely into the fill plug, it was at a slight angle. I guess I need a skinnier ratchet.
Old Jun 28, 2014 | 07:29 PM
TOM R's Avatar
When I say extension, I mean a long one to get past the parking brake drum, is the plug clear of mudd
Old Jun 28, 2014 | 09:55 PM
fishEH's Avatar
I don't use any extension. I use a 1/2" breaker bar or ratchet till it's loose, then my fingers.
DonRW2007
Jan 6, 2014 09:19 AM
ghtaylor
Jul 26, 2013 10:13 AM
usnavylt
Jun 19, 2012 10:12 PM
sk_adams
Mar 20, 2010 06:07 PM
rosalind
Aug 7, 2007 09:26 PM
