Can someone tell me what this part is?
Well I screwed up. I was changing the transfer case oil in a 97 Disco and damaged this hose. Just turning the ratchet while rubbing against the hose took out a large chunk of it. I guess the rubber from 97 is pretty brittle. Does anyone know what this hose goes to? And a part number?
Is it just rubber that surrounds the cable? It's ok to leave as is? Btw, what tool do you guys use to remove the fill plug? I used my 1/2" ratchet, but that happened. I tried a 3/8" with 1/2" adapter, 1/2" w extension, 1/2" w swivel fitting, nothing seemed to fit well in that spot.
Just to show where the parts ends:
The fill plug was empty, I had issues with clearance. The extensions made both ratchets too long to fit, and the 1/2" ratchet would barely fit along side the part that connects to the rear drive shaft. The tip would not fit entirely into the fill plug, it was at a slight angle. I guess I need a skinnier ratchet.
