Can't get O2 sensor out!
Old Nov 2, 2010 | 04:39 PM
Garrett's Avatar
Default Can't get O2 sensor out!
Tried a 16mm and 17mm on my downstream O2. Now the sensor seems to be stripped I've tried soaking it in PBlaster but nothing is working.
How should I get it out?
Thanks.
Old Nov 2, 2010 | 05:43 PM
Idle the engine for 10-15 min and then try.
Old Nov 2, 2010 | 06:01 PM
Jull's Avatar
I heated around the sensor when I changed them, and it worked well.
Old Nov 2, 2010 | 08:51 PM
XCELLER8's Avatar
you may need to know that the thread size for the sensors is....12mm x 1.25
Old Nov 2, 2010 | 08:55 PM
tweakrover's Avatar
they are hard to get out to remind you to use anti-seize when you put the new ones in.
Old Nov 2, 2010 | 10:07 PM
Long Haul's Avatar
Try some heat and visegrips if the head is stripped
KlamathMatt
Apr 17, 2020 05:27 AM
starcraft
Mar 18, 2008 09:42 PM
illuminum
Oct 8, 2007 05:34 PM
panther9
Feb 1, 2007 06:51 PM
timjescol
Mar 7, 2005 09:16 PM
