can't shift transfer case
Well fix one break two. Freed up the shifter took 15 minutes or so that picture really helped alot. Bad news it will go in gear or the slot for normal driving but it won't engage. If I put it in 4 Hi with the differential lock and slide it over in unlock and put it in gear it makes a loud gear grinding noise and won't budge. So is there a rebuild kit for the transfer case or might be better to find a working one and switch it out?
Make sure you are in neutral when making changes to the shifter
importdave
09-25-2014 10:18 PM
far4cges
08-06-2012 08:25 PM
ColeRover
02-09-2011 07:05 AM
