car stalls when ac on
What he said, the IACV is what controls the idle speed and if it is not compensating for the extra load on the engine it will stall.
Rock Auto, or other suppliers. But perhaps it can be cleaned. Remove it, use carb cleaner spray, do not move the tip, just spray all the gunk off. Also clean the bore it fits into. The tip is part of a 200 position stepper motor, don't want to force it in either direction. If you power it up (turn key but don't crank) you should see it move in or out.
firstgeer (07-12-2020)
alleescott
05-31-2009 10:49 AM
