Check engine light on....
Old Oct 25, 2011 | 08:51 PM
Well, you gotta buy oil every week or so, might be worth the trip. I live 10 miles from Egypt (there really is an Egypt, Ga), and the nearest parts store is 15 miles plus away. Point is that parts stores do this for free, repair shops charge for it. You can buy a basic scanner and it is a valuable troubleshooting tool. But auto parts place is a cheap solution. Before spending $75 - $150 on a scanner, find out what this problem is, you might be needing an expensive part.
Old Nov 3, 2011 | 08:28 PM
ESPN's Avatar
Ok, so when the rover was in the shop getting the new brake pads and a brake fluid flush, I asked the mechanic to scan for a code to see why the check engine light was on. He came back and said that it was the O2 sensors. Before I break down and buy some new ones, he's going to replace the fuel filter and the spark plugs to see if the code pops back up, hoping it's something minor like bad emissions, rather than bad sensors.
Old Nov 3, 2011 | 08:37 PM
Hopefully that will work, if he can give you the exact numbers we could provide more info.
Old Nov 3, 2011 | 08:47 PM
ESPN's Avatar
I hope it does work, O2 sensors sound like fun to replace. Plus they flush out your wallet while they're at it.
Old Nov 4, 2011 | 05:56 PM
ESPN's Avatar
Got a call from the mechanic today and the new sprak plugs and fuel filter worked! Check engine light went off. What's odd is the old spark plugs were rusty at the tip.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
