Clunk when shifting into reverse.
Old Jun 29, 2011 | 09:14 PM
calebbo's Avatar
Same problem, I never got to look at my drive shaft for the rotoflex.
Old Jun 30, 2011 | 11:17 AM
Chris-bob's Avatar
Could it be too much play in the ring and pinion gears...?
Old Jun 30, 2011 | 11:24 AM
adigerol77's Avatar
CU, does it do it when cold, just after start up or when it's warm? Mine shifts very smooth into R just after start up but after it's warmed up and has been driven for a bit, it'll shift a bit harder into R. Not hard per se but I get that sort of clunk too.
Old Jun 30, 2011 | 11:47 AM
Chris-bob's Avatar
Wait, do you all have automatics?
Old Jun 30, 2011 | 11:55 AM
calebbo's Avatar
Yes haha
Old Jun 30, 2011 | 12:03 PM
Chris-bob's Avatar
Taken from RAVE:
SYMPTOM 5 - Harsh engagement ’N’ to ’D’
Check engine idle speed
Carry out main line pressure check
oe High pressure
FAULT - Primary regulator stuck
oe Normal pressure
FAULT - Clutch ’A’ or damper for clutch’A’
Old Jun 30, 2011 | 12:09 PM
Chris-bob's Avatar
SYMPTOM 6 - Fierce shift or flare 1st to 2nd shift
Carry out mainline pressure check
oe High pressure
FAULT - Continue with symptom 5
oe Normal pressure
FAULT - Modulator valve or dampers for
clutch brake CB1 and/or clutch brake CB2
FAULT - Clutch brake CB1 and/or clutch
brake CB2
SYMPTOM 7 - Fierce shift or flare 2nd to 3rd
oe High pressure
oe Normal pressure
FAULT - Modulator valve or clutch ’B’
damper
FAULT - Clutch ’B’
Old Jun 30, 2011 | 08:02 PM
If you want the clunk to go away most of the time shift into neutral just before you stop.
I back into the parking space at work, I shift into neutral, coast a few feet, stop, shift into reverse, park.
No clunk.
Also if you stop with just the right amount of braking you can get it to go away.
Tire pressure also makes a difference, if the tires on the same axle are not at the same PSI it will make it worse.
Old Jul 1, 2011 | 12:30 AM
honda50r's Avatar
yeah, glad someone brought this up, glad it's "normal" and mine isn't the only transmission seemingly blowing up.
scootch61
Nov 30, 2013 02:49 PM
discoken
May 10, 2010 08:37 AM
DiscoMike2003
Nov 13, 2008 04:57 PM
GeorgeD
May 19, 2008 07:31 AM
turbo970
Apr 1, 2008 12:53 PM
