Code check time, 1187 & 0451
Old Oct 24, 2012 | 03:15 PM
fishEH's Avatar
Default Code check time, 1187 & 0451
Getting two codes:
P1187 Oxygen Sensor Heater Circuit Short Upstream
P0451Fuel Tank Pressure Sensor Signal Error Fault
Could these be related, have a common fault? Like a ground or connector?
Also, my code reader is VERY basic. Would a more advanced reader tell me more info to diagnose? Fore example P1186 has the same description. I assume one is for one side and the other for the other side?
Adaptive values were reset because truck was running like crap. I swapped out every damn sensor I could find. Truck runs good now but I'm getting these codes.
Old Oct 24, 2012 | 03:45 PM
They are in no way related. Have you ever replaced your 02's, sounds like it is about time.
Old Oct 24, 2012 | 06:14 PM
fishEH's Avatar
What about the code reader? Would a more advanced one distinguish between 1186 and 1187 which have the same basic description?
Old Oct 25, 2012 | 01:42 PM
wheelgarage's Avatar
It should......since it communicates with the ECU separately. The advanced reader will direct you to the bad one by designating it by code;
B1S1 - Bank 1 Sensor 1 (F.driver side)
B1S2 - Bank 1 Sensor 2 (F. passenger side)
B2S1 - Bank 2 Sensor 1 (R. driver side)
B2S2 - Bank 2 Sensor 2 (R. passenger side)
I hope I got that right....
FlyingZebra34
Feb 22, 2014 05:39 PM
Maytag
Jul 21, 2012 05:00 PM
gRover Cleveland
Jul 16, 2012 09:29 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
