Codes and help
Old 07-22-2012, 08:42 PM
bigcraigman's Avatar
Default Codes and help
I have p0103 which is mass air flow sensor value too high. I have a brand new mass air flow sensor? Don't really know what to do? Also have p0172 and p0175 which is running rich on 2 different o2 sensors. More concerned about the maf and wondering if it is causing the o2 sensor fault. Really confused what the code actually means for the Maf and suggestions what to do? Any help much appreciated!
Old 07-22-2012, 08:51 PM
Most O2 codes are caused by the need of a tune up.
Running rich usually means weal spark, either worn out spark plug and or bad plug wires.
Old 07-22-2012, 09:59 PM
Accidentally posted this is D1 forum. Whatever. Opps. I have new plugs and wires!? I have no clue
Old 07-23-2012, 03:53 AM
old sensor and new one exact same Bosch number?
Old 07-23-2012, 07:39 AM
The previous owner installed the new MAF so whether the numbers match I wil never know. They are just pending codes. I am going to clear them and see what happens today.
Old 07-23-2012, 08:02 AM
PM me the numbers on the barrel of your Bosch MAF and I will go match them with mine.
Now that I see you have a D2, I will move you back to the D2 section.
NWROVERS
03-10-2015 03:17 PM
csp
07-01-2013 07:33 AM
buick56
05-15-2013 06:11 PM
04SSHD
04-11-2012 06:20 PM
BajaXJ92
12-03-2009 07:43 PM
Quick Reply: Codes and help
