Coolant drain - water pump bolt question
Old Jun 10, 2020 | 07:08 PM
archaeology_student's Avatar
Default Coolant drain - water pump bolt question
Hello,
After watching an Atlantic British video on draining coolant for the Discovery 1 to do a Coolant drain, I didn’t see them talk too much about the bolt being removed and what to expect (e.g., a dam bursting with fluid or...).
To anyone who has done it this way, should I expect a jet to come shooting out and should I attempt to cover the belt in front?
Thank you for any and all help
Old Jun 10, 2020 | 10:39 PM
fishEH's Avatar
I've always just pulled the fill plug on the radiator, snaked a small diameter tube down to the bottom and siphoned out the coolant.
Old Jun 11, 2020 | 12:41 AM
Icannap1's Avatar
That is the best way and no mess. Just add a 5 gallon bucket to the mix.
Old Jun 11, 2020 | 12:21 PM
Have you used the coolant chemical cleaners to dislodge any of the crud in the system?
Old Jun 11, 2020 | 08:47 PM
fishEH's Avatar
Never have used any kind of chemical cleaner.
Old Jun 12, 2020 | 09:15 AM
WaltNYC's Avatar
dislodging crud comes with the risk that the crud will lodge itself elsewhere. Perhaps someone more critical.
You can have the radiator cleaned, rodded, or re-cored. Or buy a cheap aluminum model on ebay.
99DiscoFlyer
Jun 2, 2019 02:57 PM
MrWilson
Dec 19, 2018 01:05 PM
jvarnadoe
Oct 22, 2018 01:42 PM
CollieRover
Aug 17, 2018 07:33 AM
Nick Sims
Apr 2, 2017 12:49 PM
