Coolant leaking from engine block?!?!
Old 03-23-2012, 03:48 PM
leadfoot's Avatar
Originally Posted by sym3try
My assumption would be that it can probably be grabbed with some pliers once the cover is off.. I hope!
I may be stating the obvious here, but if you have enough thread to grab with pliers, don't use pliers, use two nuts and use a wrench on the inner nut against the outer nut. If it was so tight that it broke, pliers won't do any good. Again, maybe that is all you guys do, but I could not help since I see pliers being mentioned more than once.
  #32
Old 03-24-2012, 12:07 PM
LeakyDisco's Avatar
Here is an image indicating where the leak is occurring: https://imgur.com/OVuL3
Can I possibly get by without removing the cover... honestly I don't think I am qualified to take on this task (it took me an ENTIRE day just to change the water pump)
Is there a chance that simply tightening the long bolts might rectify the issue? Is there any way I can fix this without taking the whole thing apart?
Must be the weak point. I have the same leak (same spot), though I have just been globbing some hylomar blue in the area every few weeks (after recleaning it) until the coolant starts to dribble. It's a really SLOW leak, but will inevitably need to be fixed correctly. I'll probably do the job in the next month or so, before it starts getting warmer out.
I think you are going to need to pull the cover as suggested and replace the seal/gasket if you want it done right.
humroot
07-22-2019 06:33 PM
Noble Six
06-04-2014 04:51 AM
Blakesrover
02-21-2013 01:43 AM
JBEGIN
06-27-2009 12:38 PM
cptshanman
10-26-2008 10:47 PM
Quick Reply: Coolant leaking from engine block?!?!
