Cruise Control - NOT working
Old Feb 15, 2012 | 01:02 PM
thelod's Avatar
Default Cruise Control - NOT working
When I purchased this 98 Disco - the cruise did not work. So now, I want to get it working.
Here is what I discovered, so far:
It appears that all the vacuum lines are in good shape. One line, had a crack and I cut off the bad section. It appears that I am getting "vacuum" in all of the lines.
I can not find the 'switch' that is located on top the brake pedal, I have heard that sometimes, this 'switch' comes loose and goes into (behind) the firewall. But, I can see up there and/or feel anything. Should I be looking elsewhere? If yes, where?
I have heard these are the first 2 things that go bad and should check this things first.
Then the vacuum pump (which I located behind the drivers headlight area).
The "cruise" switch on the dash does light up - green.
What else should I mention? What else, should I check?
Thanks in advance, for any help, suggestions and etc.
Old Feb 15, 2012 | 02:43 PM
Brake switch vent valve. See photo - X112.
File Type: pdf
Old Feb 16, 2012 | 10:27 PM
reboot's Avatar
My cruise button lights up amber on the dash on my 98. The fog light next to it is green. hmmmm My cruise is OD also. I thought when I got my VSS working I would have cruise control. I don't feel any vacuum on my hose and it is connected for sure.
There is also another updated thread on cruise control recently in here. https://landroverforums.com/forum/di...working-47326/
Old Feb 18, 2012 | 08:39 PM
reboot's Avatar
Another question, when you got a vacuum on the line, did you test that while the vehicle was in park or neutral with the Cruise control button on the dash on or what?
Carlton1
Jul 25, 2012 07:51 AM
csn4646
Aug 28, 2009 09:16 PM
2K Disco II
Aug 11, 2008 10:42 AM
cosmiccharlie79
Jun 16, 2008 09:13 AM
bklahl
Aug 29, 2007 11:20 AM
