Cruise and shocks questions
Old Nov 12, 2013 | 10:03 AM
Snowdog's Avatar
Default Cruise and shocks questions
First, my cruise isn't working. I have checked the vacuum lines and they seem to be crack-free, the light on the switch comes on, and I can hear clicking when the brakes are applied, and (it seems) when I activate the "set" switch. Cruise ECU? I know with a little soldering a DII unit will work. Anything else to check before replacing the ECU?
Second: What shocks are recommended? I'm looking for a factory-like ride (read: soft and smooth), no lift, mainly on-road and light off-road use. I'm looking at the Boge units that are supposed to be OEM.
Thanks!
Old Nov 12, 2013 | 02:01 PM
wrongway1's Avatar
Okay, had the same issue with the cruise control. Found a NOS still in the box on line. Wasn't fun putting it in, but works perfectly. I went with the terrafirma standard shocks from AB. Liked the ride with the stock springs.
Old Nov 12, 2013 | 05:22 PM
TOM R's Avatar
I like my bilstien. Shocks
Old Nov 13, 2013 | 07:22 AM
tylor36's Avatar
I second the bilstiens, I have them on mine and the ride is pretty comfortable. Mine look pretty beat and are quite rusted, but they have not failed yet so I will keep them until they do.
Old Nov 13, 2013 | 09:20 AM
Snowdog's Avatar
I've installed Bilsteins on a few previous vehicles, and they were too stiff for unloaded driving (although when hauling/towing heavy loads they were great), so I am hesitant to spend the money and find the same thing when installed on the Disco. This is our "comfortable riding" vehicle (the others - a Mini Cooper Clubman S with the optional sport suspension and a diesel F250) already ride stiff enough, so the softer the Disco is, the better. I think Bilstein makes a high-quality product, but I find their valving too aggressive for our roads, at least the ones I have tried.
Old Nov 13, 2013 | 10:34 PM
houmem24's Avatar
4wd High
Hi Snowdog,
Did you fix your Cruise?
Old Nov 14, 2013 | 01:54 AM
rover109's Avatar
Re: Cruise control
I bought multiple used ECU's from ebay etc where the sellers told me the ECU came from a working truck, so they assumed it worked. They never did. I finally emailed sellers first & finally found a seller who confirmed the ECU he was selling worked by trying it in his truck before he shipped. No cruise control problems since. (Knock wood)
joyntanovich
Aug 31, 2013 10:01 PM
CoastieDisco2
Oct 16, 2012 08:05 PM
hh65flyer
Apr 2, 2012 04:47 PM
adam123
Apr 5, 2011 09:11 AM
avking
Feb 18, 2009 05:10 PM
