D1 Brake Light Trouble
Old Jul 21, 2011 | 10:16 PM
modernhomesteader's Avatar
5th Gear
Default D1 Brake Light Trouble
I had brake light issues when I bought my D1. Only 1 rear tail lamp would light up when the brakes were applied. The high-level (3rd) brake light always worked fine. I took the lamp assemblies out and found the plastic sockets around where the light bulb holders screwed in were starting to melt and one of them was tough to get out to check the bulb elements. I replaced the bulbs but soon both went out. I noticed more melting around the sockets. Guessing that these 2-element bulbs had been burning constantly due to a stuck plunger switch on the brake pedal (this has happened to me on another vehicle) I replaced the plunger switch. Now the brake lights still dont work. The third light works. The running amber lights work as does the back-up white lights, as do the turn lamps. I replaced one of the rear tail lamp assemblies (55 bucks on eBay) and it still doesnt light up.
I suspect the 3rd brake light is wired differently but the shop manual doesnt seem to have schematic for the 3rd brake, it just shows the two rear brake lights in the circuit.
Does anyone have more detailed info (more detailed that shop manual) on how these are wired through the body so I can check for rubs/grounds? Can anyone confirm how the 3rd brake light is wired? Is it on a circuit with something else in the rear?
Old Jul 21, 2011 | 10:33 PM
If you look in the RAVE at the electrical troubleshooting guide, which is separate from the workshop manual, there is a section on Stop lamps, "K". Info you want is on page 2 of that section, or you can search for "Centre Mounted Stop Lamp" - the King's English. Also has schematic, and location of connectors, splices, relays, etc.
Old Jul 22, 2011 | 12:15 PM
WaltNYC's Avatar
First, I presume you are talking about the body mounted lights, not the bumper. If you have melting of the bulb holders, replace them first. They may be preventing ground. Use new bulbs also. Spend $10 first. If might be that simple.
Matt_Attack352
Jan 13, 2014 09:55 AM
rreinholt
Oct 10, 2013 08:47 AM
Florida04RR
Mar 10, 2010 06:09 AM
geoffthepoolguy
Feb 12, 2010 06:10 PM
bigbris1
Jul 3, 2007 08:02 PM
