D1 discovery power steering hose routing
Old Dec 16, 2019 | 01:46 PM
brandon4589's Avatar
6th Gear
Default D1 discovery power steering hose routing
Hi I’m trying to replace the leaking power steering hoses and I’m not sure the po put them in the right location, it seams wired it is very close to the exhaust manifold, can someone please take a pic of the hoses? Rave was not very clear
Ps hoses
Old Dec 16, 2019 | 08:09 PM
Best4x4's Avatar
Loosen the end on the PS Box and rotate it so the hose moves forward away from the exhaust manifold. RAVE Manual is your friend for diagnostics/schematics
Old Dec 16, 2019 | 09:38 PM
6th Gear
It isn't very clear
Old Dec 17, 2019 | 03:31 PM
Best4x4's Avatar
Pic shows the hose coming around from the front vs back. Like I said you can try loosening the connection at the box & rotating the hose forward away from exhaust manifold. Or remove it & re-route it.
Old Dec 17, 2019 | 06:25 PM
OverRover's Avatar
Just a headsup, you don't want to route the Low Pressure Hose ( NTC9989 / Reservoir to Pump ) over the lower U-joint on the steering shaft.
That joint will put a hole in that hose real quick!
Old Dec 17, 2019 | 06:55 PM
stillruns's Avatar
I’ll take a pic of mine in the morning and post it. 98’, what year is yours?
Old Dec 18, 2019 | 09:41 AM
stillruns's Avatar
brandon4589
Dec 16, 2019 12:38 PM
TRIARII
Sep 11, 2014 07:42 PM
secondtimerover
Nov 17, 2012 07:31 PM
sorusty
Jul 18, 2011 11:17 AM
opus13
Jun 4, 2006 03:15 PM
