Dash lights/rear wiper not working, fuse blowing
Old Sep 22, 2015 | 08:19 PM
green-lantern's Avatar
Originally Posted by ihscouts
Wash/wipe - rear, mirrors, cruise control. Might want to disconnect that too. CC switch, rotary coupler, steering wheel switches, and CC ECU. Those are all on fuse 18.
I misread your original post saying NOT. sorry lol
I think the only thing on your list I didn't unplug was steering wheel buttons. Not sure what the "rotary coupler" is though.
It's frustrating because right after I get the pile running the rear windows, gauge lights, rear whipper quits working.
I did check every single fuse and the only one that was blown was 18.
Old Sep 23, 2015 | 02:33 AM
ihscouts's Avatar
The RC is a device which has continuous contact between the steering wheel and column. Turn signals, horn, air bag, cruise switch contacts. It's like the copper ring under the steering wheel in older vehicles.
Old Sep 24, 2015 | 04:22 PM
Both tied into HJ8 behind the instrument cluster. White connector with a bunch of black wires going to it, all grounds. Which fuse is blowing? The rear wiper is not the same fuse as the dash lighting. F18 10A is for wiper, F8 10A for interior lights and both drivers side fuse panel under wheel.
Hey where do those grounds actually hook to ground/frame/body? If I turn the stereo up the stereo will cut off like it has a bad ground.
Old Sep 24, 2015 | 05:46 PM
ihscouts's Avatar
E201 which is behind the drivers side footwell kick panel. And guess what, the radio is also grounded at the same location...... I think we have a winner, winner, chicken dinner!
Old Sep 25, 2015 | 01:46 PM
I was hoping it would be the same as the radio. I don't need to remove the fuse box correct? Just that panel?
Old Sep 25, 2015 | 02:41 PM
Well still no obvious damage, ground looks good. I guess next thing is pulling the fuse box and start tracing the grounds up. :/
Old Sep 25, 2015 | 03:21 PM
ihscouts's Avatar
You don't need to remove the fuse panel for that ground location (huge pita). If you have the 95's ETM there's a pic of it behind the kick panel. Have you checked the common block behind the instrument panel?
Old Sep 27, 2015 | 09:58 AM
I'm not sure where that is. I pulled the instrument panel and didn't see any damage. don't remember seeing a common block.
Old Sep 27, 2015 | 10:25 AM
Under the power window switch.
Little rat bastard!
Anyway hopefully this will be all the damage.
Old Sep 27, 2015 | 12:19 PM
Well good news and bad news
The instrument cluster lights are working now and #18 fuse isn't blowing
But rear windows and rear wiper still aren't working.
