Dash lights/rear wiper not working, fuse blowing
Old Sep 28, 2015 | 06:16 PM
  #31
ihscouts's Avatar
You guys gonna get some cooler weather in the next few days? I can't stand twisting myself into a pretzel under the dash, never comfortable. Have you checked behind the passenger kick panel yet for more fluffy stuff?
Old Sep 28, 2015 | 06:49 PM
  #32
green-lantern's Avatar
Yeah it's getting cooler, been pretty nice lately really. I'm getting too old to do the dash dance lol. I have not checked the passenger side kick panel yet. That's where the ECU is right? I just figured the damage is between the rear window switch and stereo to hot or ground. Most likely hot since I wasn't getting power to the rear window switches, not much anyway. I think I got 5 volts one time.
66 is the high for Friday.
Old Sep 28, 2015 | 07:44 PM
  #33
ihscouts's Avatar
Yep, we're getting cooled off finally too. The window lift ecu is in behind the glove box. The multi-function unit is behind the fuse panel and there's a couple of relays behind the drivers kick panel. I was just wondering if anything chewed over yonder in the passenger side....... another common ground is over there........
Old Sep 29, 2015 | 04:42 PM
  #34
I found this video searching "window lift ecu land rover discovery" and it appears the rear window problem might be sort of common. They say the solder points get bad. I've fixed a few ECU's so if that's the issue it won't be a problem to fix. I'm still going to check the passenger side kick panel. If I get the windows working the only thing left is the rear wiper and honestly I can live without it. I'd like to have it but oh well.
Old Sep 29, 2015 | 05:29 PM
  #35
ihscouts's Avatar
You know, I never even thought of it and yes it's widely common. Worth a shot, I reflowed mine and it fixed it. I thought you had already been there, my apologies.......... My rear wiper hasn't worked for several years, I don't use it nor need it but yeah, it's nice to know it works.
Old Sep 29, 2015 | 06:59 PM
  #36
OK, I got the ecu out and did find a solder joint that looks cracked. It took me a while because my eye site seems to finally be going (in darker light anyway) but it doesn't quite look bad enough to me. It IS on the exact spot he originally pointed out in the video though. Since mine worked some of the time it could be the problem. I'm going to suck the old solder out and replace it with new hoping it will be the problem.
Old Sep 29, 2015 | 07:12 PM
  #37
The more I look at it the more confident I found the issue. It is cracked all around and it's the relay part.
Old Sep 29, 2015 | 07:31 PM
  #38
winner, winner, chicken dinner!
Ithankya!
Win!
Don't ya love it when you finally find an issue!
Old Sep 29, 2015 | 07:36 PM
  #39
ihscouts's Avatar
Two down, one to go. I'll see what I can find out about the rear wiper....... it would be cool if I could get mine going too......
Old Sep 29, 2015 | 08:04 PM
  #40
I wonder if it has something to do with that multi-control module/ecu you were talking about? I don't know what really controls it.
