DI cruise...
Old Jul 26, 2016 | 03:49 PM
fishEH's Avatar
I used 5/32" vacuum tube. I would guess about 10-12' would be enough.
Old Jul 26, 2016 | 06:32 PM
notny41's Avatar
Well, just for the heck of it, I went out and pulled out my Cruise Control module and took the aluminum cover off of it looking for poor solder connections. I didn't see anything that looked questionable til I looked at the pins on the connector.
The number 8 pin (which is the ground pin) was completely covered with corrosion.
I cleaned that pin up as best I could with a screwdriver and sandpaper and then put some vasaline on all of the pins and reinstalled it.
I have cracked vacuum tubing all over so I will get some new tubing and put it on too. I'll have to wait to try it out though until I get my new fuel pump installed.
If it still doesn't work now, I have an AMR5700 on the way, which I was planning on using til I saw my corroded connector.
Hope this helps someone in the future.
Paul
Old Jul 26, 2016 | 06:44 PM
notny41's Avatar
So that would be 4mm equivalent then? I measured the stuff that I pulled off, it looks to be 5mm inside diameter. Do you think one is any better than the other?
I also measured the "T" at it's narrowest point and it looks to be 6mm.
Old Jul 26, 2016 | 07:40 PM
fishEH's Avatar
Yes, 4mm. Its a tight fit on the different nipples, but it goes on easy enough.
Old Jul 27, 2016 | 09:10 AM
notny41's Avatar
Did you use hose clamps too or not?
Old Jul 27, 2016 | 09:19 AM
fishEH's Avatar
No hose clamps. Just push the hose on and you're good.
Old Jun 23, 2020 | 11:00 PM
DiscoNewbe's Avatar
Did cleaning up those corroded connections work? What ever happened with your cruise control?
37chambers
Oct 18, 2016 10:52 AM
preston
Sep 11, 2006 04:12 PM
UNCRover
Jun 10, 2005 12:23 AM
anonimaus
May 9, 2005 10:01 PM
flowers
Apr 12, 2005 04:03 PM
