Disco 1 won't move in gear
Thanks, guys....I found a couple of TCs in the local yard for 165 USD...one's a '96, and the other is a '99 (which looks pretty clean).
I'm going back this weekend to pick one up (after I pop the plate to make sure it's not trashed, lol).
I'll report back next week.
Rob
Rob
Before I go busting knuckles, can I be sure the unit will fit, and is interchangeable?
My truck is a '97 NA model, and the salvage yard truck is a '99 NA model...other than the drain plug looking different, I couldn't see any differences in the cases....
Rob
Rob
AFAIK your good to go. 97 - 99 pretty much all the same birds with some minor improvements each year. Nothing changed drastically within the driveline to make a 99 not fit or work well. 94/95 work with each other and the 96 carried over some stuff from those years, some was new and some was changed in 97 from lessons learned in 96 being the first 4.0. Make sure the 99 is a D1 and not a D2.....just to keep things simple. Again the differences wheren't that wide but the D2 uses a dc front shaft.
Scouts that could be the illusive 98 D2 p38 Bosch lol
But seriously check the fluid and you should be fine, if there is a lot of slop in your drive shaft slip joints might want to grab those, also do u joints front drive shaft
Guys...I'm in the salvage yard now, a I have the TC out and on the ground, but the high/low lever on this one isn't moving, either. Should I be able to shift this ny hand, or is it dependant on the truck trans running, or electrical power going to it? I don't want to spend the money, if this one is also crapped out....
Rob
Rob
