Disco I Flashing Oil Light
Old Sep 2, 2012 | 12:27 PM
Originally Posted by Danny Lee 97 Disco
Rotella 5W-40
I would be willing to bet the problem is the 5w40 oil.
5w anything is too damn thin for these especially with higher milage and higher temps.
15w40 20w50 or straight 40 weight would be a much better choice.
Rotella is fine but you need rotella 15w40 or Castrol GTX 20w50. So drain that 5w and put in onme of the above before you screw that motor up.
A 5/40 and a 15/40 act the same when the engine is hot and will not cause that problem, they are both 40 weight oils when hot.
If it were mine, I would do an oil pressure test, cold at idle and at 2000 RPM's and again when hot at idle and at 2000 RPM's. Get back to use with the 4 sets of numbers.
Either your pump is cracked, you have a bad temp sensor or you have some serious crank bearing issues.
devildollnyc
Dec 25, 2018 05:12 PM
importdave
Sep 25, 2014 10:18 PM
devildollnyc
Feb 13, 2011 01:51 AM
shonuff93
Sep 21, 2009 03:57 PM
gsgtsg
Jan 23, 2008 01:46 PM
