Discovery 1 automatic transmission types
Old Aug 14, 2024 | 03:09 AM
Gee's Avatar
Gee
4th Gear
Default Discovery 1 automatic transmission types
Hi
I just had my D2 TD5 destroyed is a vehicle accident, no one hurt but she's a right off.
I have a 1998 D1 300TDI with an automatic gearbox playing up, loosing drive.
I have been offered a low milage D1 Automatic gearbox for my D2 wreckage which was mechanically going well.
I am not sure if all D1 transmissions are the same.
Information I am seeking is:
Are all Discovery 1 automatic transmissions the same regardless if the come from a different year or engine type, diesel or V8's.
Would anything need to be changed if from a different engine type.
Would it be prudent to get transmission disassembled.
Are the torque converters the same on all models.
Any other things I should look out for.
Any assistance appreciated.
regards
Gino
Old Aug 14, 2024 | 09:44 AM
DHTaylor's Avatar
You are likely not able to swap the transmissions.
There are two main differences between the ZF 4HP 22 and 4HP 24. First: Gear ratio. In 2003/2004, the Discovery was pushed to the 4.6L. In doing that, Land Rover pushed the transmission with a larger gear ratio in 1st & 2nd to get the vehicle in line with more horsepower. This is not an issue if you want it in the D1.
The second thing is the kick down. I have a D2 transmission - low mileage - sitting in the garage that I just got off eBay. I thought I could configure it to work on my D1. Nope. There is no mechanical kick down on the ZF 4HP24 - they use electronics. The ZF 4HP22 uses a cable that runs to the throttle body on the GEMS engines. This is the big difference between the 4HP22 & 24. You would certain love to have the different gear ratio and bigger torque converter. But, you have no way of plugging in the electronic kick down.
Old Aug 14, 2024 | 04:28 PM
Gee's Avatar
Gee
4th Gear
Hi
Thanks for the reply.
I might have confused the information.
I was not looking to put a D2 into a D1, I was after details of the D1 transmissions if they were the same from a D1 V8 or the D1 diesel versions and could be used.
regards
Gee
disco96sd
May 26, 2021 10:43 PM
Beaulim
Feb 4, 2015 11:29 AM
ESPN
Dec 2, 2011 11:58 AM
nhwheelin
Oct 31, 2009 06:09 PM
roverboy
Dec 6, 2008 09:26 AM
