Discovery 1 cruise control
Honestly you're looking for trouble tearing things out just because they're "not worth having." It's a 20-something-year-old truck, the few pounds of wiring you might remove just because some systems don't need to be there is not worth the hassle if you mess something up. Leave it alone. Also, you removed your brake light switch? How's that working out?
You can remove the ECU no problem. I wouldn't bother with the wiring.
