Discovery 1 cruise control
Hi everyone.i have removed the cruise control mechanism under bonnet. Switch off the brake pedal.does anyone know if i removed the ecu and wiring would it affect anything. Why .because its not worth having on .cheers chaps.
Honestly you're looking for trouble tearing things out just because they're "not worth having." It's a 20-something-year-old truck, the few pounds of wiring you might remove just because some systems don't need to be there is not worth the hassle if you mess something up. Leave it alone. Also, you removed your brake light switch? How's that working out?
You can remove the ECU no problem. I wouldn't bother with the wiring.
