Discovery 1 shifts out of park but the breaks are still
Old Jan 28, 2018 | 05:57 PM
zmartinez117's Avatar
4th Gear
Question Discovery 1 shifts out of park but the breaks are still
My car was recently in a wreck and the engine is running, everything seemed to be working this morning. After changing out the headlights we tried to take the land rover out for a test drive and the brakes suddenly wouldn't let the car even budge(we could still change gears and move the shifter). After waiting about an hour we tried again and this time if we pressed down on the gas the car would move but it was like the brakes were still stuck, after driving the car we could see smoke and smell the breaks burning.
Any thoughts on whats wrong?
Thanks
Old Jan 28, 2018 | 06:42 PM
jimvw57's Avatar
Possibly a pinched brake line or a broken (or missing) caliper bolt. when that happens, the caliper jams on the inside of the rim and locks things up. Been there!
Old Jan 28, 2018 | 09:21 PM
alpinacsi's Avatar
Are all brakes smoking? Did you do a walk around and check all corners? If one caliper is binding it should not affect all corners and if only one front is binding: you should feel it pulling that direction. And I assume e-brake is off.
Old Jan 28, 2018 | 09:29 PM
4th Gear
Yeah I actually think only the front right break was smoking, maybe the front two don't remember completely. And yes e-brake was off.
Thanks for the reply.
Old Jan 29, 2018 | 10:25 AM
DavC's Avatar
Agree with others
check your brake lines, calipers. jack up the vehicle, see which wheels will move and which will not. Move forward and service your brakes depending on what area is the issue (stuck caliper, pinched line, etc.
Fishman
May 20, 2014 10:28 PM
Dburnell
Aug 21, 2013 11:44 AM
duncanskyler
Apr 8, 2010 06:54 PM
