Discovery eletrical problems
Old Jul 18, 2012 | 09:02 PM
And for what it is worth, my 97 would not "re-learn" a new IACV, and I swapped the ECU with one from the junkyard, and have been driving for over a year, don't believe any re-sync is needed with the Lucas alarm module. Now on a D2 that is a different matter. And maybe I'm just lucky.
Old Jul 18, 2012 | 09:12 PM
Danny Lee 97 Disco's Avatar
I have seen write-ups from some saying that a mismatch is a problem and some who had no problem. LR made so many "on the fly changes" it may be according to VIN or some other flakey reason.
I bet our new member from Wales (Gramme) could give some detailed guidance.
The main point I was stressing was did they read any codes and how did they determine what to change?
Enny, Meanie, minnie, mo? Which a way should I go? Throw darts, draw staws, 'or whatever Bubba came up with? Or maybe what was in inventory? Did the owner still have to pay for all the guess work and un-needed parts and extra labor and more incorrect guesses??
Damn did I really say that?
Old Jul 19, 2012 | 07:11 AM
Imports_Only_Inc's Avatar
6th Gear
we hope to fix the LR too, its giving us too much stress. Right now we are waiting for another properly working ECM to come in since the other one we ordered isnt worth its weight in metal.
Old Jul 19, 2012 | 02:49 PM
ihscouts's Avatar
Hopefully the AS10 isn't in lockout mode or no start again with new ECM.
Old Jul 19, 2012 | 04:14 PM
Why not reinstall thye original ECM and see if that restores it to just the original problem?
Every new "shot in the dark" changeout introduces additional variables and can send a simple fault isolation effort into a ever ending fiasco. Especially if the alarm system has been set off.
How long you been doing imports only? Not much Land Rover Expertisse I would venture to say.
You did not answer if you read any codes to begin with or what you did to identify the potential cause or why you changed out what you did.
They are called Discovery because everything yopu start to do leads to another "Discovery", especially if they have not been properly maintained in the past and they may have multiple contributors to begin with.
The flash rate of the dash mounted alarm red light will also tell you a lot!
You can get the matching alarm ecu to go along with the replacement ECM.
What is the available budget? Deep pockets I hope.
Old Jul 19, 2012 | 04:16 PM
Is Hollywood's Midnight Repair shop still in business there in Warner Robbins?
He fixed my Grand Am one weekend when it crapped out on us on I-75 on our way back to Florida from Pittsburgh.
My hometown is up 19-41 from you. Griffin Georgia Redneck here.
Old Jul 26, 2012 | 01:48 PM
6th Gear
we are still trying to figure out how to override security to get the engine cranked. the old ECM does not work now, it ends up with same results as the new one. alarm sounds more often when door is opened.
Old Jul 30, 2012 | 11:51 AM
Since the security system kills both spark and fuel injection, thaqt may be quite difficult undertaking. Let us know if you do manage to do that. Some of the English Blokes have gone into great detail on doing that.
Old Jul 30, 2012 | 11:52 AM
You might try to get a matched pair of ECM and Alarm ECM or try a landrover dealer cause you need their proprietary software I think.
They can "reflash" the ECM for you usually around a hundred bucks or so at most dealerships.
Frank4
Mar 21, 2014 05:21 AM
coldstart
May 8, 2011 07:01 PM
Roverboy3766
Nov 13, 2007 07:04 PM
Sean 1313
Aug 30, 2005 10:17 PM
dma3
Apr 2, 2005 02:55 AM
