Dont do this!!!
Old Jun 25, 2013 | 07:09 PM
jdblep's Avatar
Default Dont do this!!!
So i was cleaning my IACV and oil separator, and checking vacuum lines, everything was going great.. They all were dirty, and i was hoping that this would cure my persistent P1179 (already cleaned intake and MAF) Then i start putting it back together, and one of the bolts snaps off on the IACV.
Just a reminder to all of you out there, be careful with those fragile aluminum parts!
Now i got to check the classifieds/ebay for a new intake/throttle body... What was a 15min job is now going to be several hours (and probably $100 bucks)
Old Jun 25, 2013 | 07:12 PM
So you are going to drill the snapped bolt and use an E Z Out?
Old Jun 25, 2013 | 07:58 PM
CUpgt's Avatar
Left handed drill and an easy out and you should be good. You should have heard the string of curse words fly from under my truck when I broke a pinion bolt off in the pinion. Luckily the above method had me up and running again in no time.
Old Jun 25, 2013 | 09:25 PM
jdblep's Avatar
i started trying to drill it out on the truck, but there was too much $#$&* in the way. Guess i could try pulling the intake off and using an easyout on it. those bolts are so small, not sure if i can find an EZ out small enough. could maybe drill it out bigger, and re-tap it?
Old Jun 25, 2013 | 11:53 PM
CUpgt's Avatar
They make tiny easy outs. The set at auto zone has some small ones
Old Jun 26, 2013 | 11:56 AM
Higgs Boson's Avatar
Location? I have a spare upper plenum I may part with if you are interested.
Old Jun 26, 2013 | 12:55 PM
jdblep's Avatar
in Lincoln, ne 68505
Old Jun 28, 2013 | 12:02 PM
Thought I could help you, I can't figure out what I did with my spare plenum. I found a bunch of other stuff though, I'll keep looking for the plenum and let you know.
Brad S1
Jan 23, 2018 09:02 AM
armyeng
Mar 8, 2011 05:58 PM
v8man1
Jan 22, 2008 10:49 PM
team510
Nov 22, 2007 06:33 PM
roverrick
Nov 9, 2007 01:19 PM
