Door lock barrel rod problem
Old Dec 1, 2010 | 10:32 AM
batiscan's Avatar
Default Door lock barrel rod problem
I'm unable to lock/unlock the passenger side lock using the key.
I check for any disconnected rod and here's what i found: all was fine EXCEPT:
The U-shaped control rod that runs behind the window track connects the barrel lock to a bellcrank that also connects the electrical actuator and interior door lock together. Ok until now.
When I lock/unlock with the key, the whole U-shape moves up and down. However, from what I see, the part that's behind the window track should not move but pivot for the whole thing to work.
Does anyone know if that's right and what should be holding the rod so it pivots properly and how to fix that...It's not the most accessible place! RAVE does not show these details. The picture shows some kind of holder on the left side of the track. Don't know if it's broken or if the rod has jumped out...will try to push it back in.
The following pictures show the rod in the up and down positions.
Thanks for any hint.
Attached Thumbnails Door lock barrel rod problem-img_5241_1.jpg   Door lock barrel rod problem-img_5242_1.jpg
Old Dec 1, 2010 | 11:23 AM
okdiscoguy's Avatar
I will tell you from my experience witht he door locks. If you hold up on the lock and the handle opens it, but no other time, it is a little spring in the door mechanism. There is a guy on e-bay that sells them from the UK. I had 2 passenger doors and the rear door that would only open if the lock was held up. YOu could unlock the door, but it would fall right back down...
Old Dec 1, 2010 | 12:30 PM
Danny Lee 97 Disco's Avatar
I see some corrosion in your pics, plus the mechanism looks "loose".
Sorry I cannot be more helpful, I have never had to tear into the doors yet. That is the first time I have seen those linkages.
Did you try Rovers North for parts?
Old Dec 1, 2010 | 12:41 PM
Chris-bob's Avatar
Check Chapter 76 Chassis and Body pages 4 and 6 of the Rave manual for a diagram.
Old Dec 1, 2010 | 03:33 PM
batiscan's Avatar
Thanks guys but RAVE is what's what I had been looking at: it shows the linkages but not how the u-shaped rod is held in place.
As to Rovers North, they don't show replacement parts graphics for the door lock. I'll probably give'em a call once I know if anything needs replacement ...
Old Dec 1, 2010 | 05:20 PM
Chris-bob's Avatar
Sorry, I misread your original post. I'd imagine the u-shaped rod is held in place with the metal clip that I can see in the pics. Can you get it pushed into the clip with your fingers or a screwdriver?
Old Dec 1, 2010 | 06:09 PM
batiscan's Avatar
I tried with a curved handle but didn't clip or catch into anything although it does look like it should. The pictures were taken by inserting a small camera in the door. I don't have that kind of view when I work on it so it's pretty much trial and error...
okdiscoguy's Avatar
Ok, I wasn't seeing it. Looks like the back part of the rod has popped out of the holder. It should be secured to the back where the arrow is.. may have popped out, or the holder may be busted..
Old Dec 5, 2010 | 07:35 PM
batiscan's Avatar
I tried to get it back in but no success. From pictures of online catalogs, I found that this is part of the lock assembly. Next step would be to remove the window frame and get the lock out but I won't get into this now, it's not critical enough (especially with a forecast of 6 in of snow).
Thanks again for everyone's input.
Old Dec 7, 2010 | 12:00 PM
The CDL Linkage has similar little clips and such. I would take a good look at those. These linkages are really poorly designed and manufactured in my opinion.
jigray3
Oct 1, 2014 07:32 AM
swearinoutloud
Jul 23, 2014 10:04 AM
nicke
Nov 1, 2012 12:34 PM
harro123
Mar 27, 2011 06:15 PM
denis06
Feb 29, 2008 09:58 AM
