driveshaft play?
Old Feb 7, 2011 | 09:33 PM
adam123's Avatar
Default driveshaft play?
all 4 wheels on the ground, how much play should there be in the front and rear driveshafts? i was greasing things up tonight and grabbed em both. i can rotate the front about a half inch, and the rear about quarter inch. is this play normal?
thanks
adam
98 D1
Old Feb 8, 2011 | 07:54 AM
Call it pretty normal. Do you have any t/case noise?
Old Feb 8, 2011 | 08:07 AM
adam123's Avatar
Thanks for the reply.
Yeah i get a little noise. nothing while cruising, but i get a mild clunk on acceleration as it takes up that play, and 2 small ones when deceleration, U-Joints are all good. Its almost like you can hear the tranny downshifting out of from 4 to 3 and 3 to 2. Knowing now that the play in the shafts is normal it would seem likely that the noise is too.
Old Feb 8, 2011 | 08:33 AM
kenk's Avatar
Does you're transmission shift fine? clunking sound( other than the little one going into reverse) is not normal, especially on downshifting.
A clunk on acceleration is usually the drivetrain taking up slack of a bad u-joint or worn ring and pinion. But on deceleration(downshifting), not normal. Almost sounds like the trans.
If you never have, drain the fluid and refill adding a bottle of lucas trans additive. That works pretty good for smooting out rough spots.
Old Feb 8, 2011 | 08:50 AM
adam123's Avatar
transmission shifts fine, the noise on deceleration is like a pair of small pops. doesnt sound like its coming from the transmission. id be willing to bet is bushings binding up somewhere on the body or suspension, i'll try to pinpoint it better on the way to work later.
Old Feb 8, 2011 | 08:55 AM
kenk's Avatar
Hmm, if it indeed is not the trans, I would look for something binding up.
robert.juric
Nov 3, 2022 06:08 PM
xmarksit
Nov 26, 2013 08:37 AM
countyrover
Oct 28, 2005 09:39 AM
Evian
Aug 18, 2005 11:34 PM
Bene
May 23, 2005 01:00 PM
